Discussion topic: WiFi
This message was authored by: Kirsty158
WiFi
My WiFi is not working it's got a orange dot in middle
Re: WiFi
@Kirsty158
Your duplicate thread has been removed to prevent repeated replies.
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
