Discussion topic: WiFi won't work
This message was authored by: Livvy6
WiFi won't work
WiFi won't work and I've tested it and it says the connection is fine but won't connect on my phone.
Re: WiFi won't work
@Livvy6 loss of service between midnight and 5am is often duecto essential maintenace so if your connection is now back working thst was the likely explanation. If it isnt run the service checkercagain as that takes up,to an hour tompick up dropped connections.
