Discussion topic: WiFi won’t connect
This message was authored by: ML16
Message posted on 27 Dec 2025 09:49 PM
WiFi won’t connect
WiFi was working then dropped out whilst streaming Netflix. Have rebooted but get two green lights and two amber on the router and it won't connect
Message posted on 27 Dec 2025 10:36 PM
Re: WiFi won’t connect
@ML16 Try this after an hour or so!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
