Discussion topic: WiFi won’t connect to any mobiles
This message was authored by: Margaret72
I have a new ish sky hub but none of our mobiles will connect I've tried everything that they suggest and I'm getting no where
Re: WiFi won’t connect to any mobiles
@Margaret72
Are you entering the wifi network key (password) correctly so using a letter O into of a number zero if needs be and that it if is in uppercase that you enter it in uppercase ?
Avatar for Margaret72
yes done all that everyone in household is having same problem
