Discussion topic: WiFi weak and smart TV buffering
This message was authored by: David592
Message posted on 27 Dec 2024 05:50 PM
Hi, my smart TV is connected using WiFi and is not working well
Find out more
Message posted on 27 Dec 2024 05:58 PM
Re: WiFi weak and smart TV buffering
@David592 to stream video you nedca steady wifi connection which it sounds like you dont have. You can check the speed at the TV by running the netwirk test in the Get Help menu of tge Netflix app. You need at least 25Mb/s to watch UHD material.
Sky can sell you an add-on called WiFi Max if your current Sky hub ca nt provide sufficent signal to your TV see https://www.sky.com/help/articles/sky-wifi-max
