Discussion topic: WiFi - warzone
This message was authored by: Stokes30
WiFi - warzone
Hi
have had sky wifi for a few month now, has been working perfectly now I'm getting issues from Thursday last week.
call of duty - on ps5 can't either connecting to online services or find a match. Fives errors codes relating to network issues. Ps5 connects to internet and signs into PlayStation network but it's as if something is stopping it actually using internet.
similar with my smart tv, no apps are showing as if it is not connected to the internet and only Netflix works, it loses connection often which never previously happened. iPhone when on wifi struggles to load pages
my sky app sometimes detects issues, when I click to check and fix all is fine.
any ideas?
Re: WiFi - warzone
Hi @Stokes30
Do other devices work fine? Can you see if everything works over ethernet?
I am NOT a Sky Employee
Avatar for Stokes30
Re: WiFi - warzone
Sort of, everything is just very slow, Netflix on another smart tv lastnight kept lagging and taking ages to load, not just stream even basic commands like scrolling through films
main smart tv next to the hub shows no apps but if I press the Netflix or Amazon button on the remote they open and are connected
same with PlayStation connects but as if it doesn't have enough signal or if being blocked to play warzone and connect to there servers
have changed the setting to wap2 still the same
some websites don't open on my phone if I turn off wifi open right away with my 5g signal
worked great for months
was better then my starlink
Avatar for Stokes30
Re: WiFi - warzone
