Discussion topic: WiFi strength
This message was authored by: Sam19811
WiFi strength
My wifi won't work in my garage. Where the router is and where the garage is they are in opposite corners and the signal isn't strong enough to reach Can you help please.
Re: WiFi strength
@Sam19811 getting a wifi signal into a garage is always tricky due to thick walls. The easiest solution is to use powerline networking adapters with a built-in wifi access point which uses your home's mains wiring to carry the data.
You buy a kit with two adapters , the first adapter simply has an ethernet socket and is plugged into a wall socket near the hub and connected by an ethernet cable to a LAN socket on the hub. The adapter which has the built-in access point is the plugged into a power socket in the garage. These work quite well but only expect between 20 to 30% of the rated output in most homes. If you buy online you can return the kit within 14 days if it doesn't work in your home.
