Discussion topic: WiFi stopped working
This message was authored by: Malcolm44
Watching TV and WiFi stopped; now all connections lost. No WiFi
Re: WiFi stopped working
@Malcolm44
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
