Discussion topic: WiFi speeds awful past 5 days
This message was authored by: Jde27183
sky internet slow 7mbs in b31 area the past 5 days I have SEND children who relies on the internet. I usually get 34mbs now get 7mbs and can't stream anything I have tried resetting my hub still awful, any help will be much appreciated
Re: WiFi speeds awful past 5 days
@Jde27183 Call sky dial 150 from your landline! Also below worth a check by yourself!
Try running the line test here to see if any faults are found:
Avatar for Jde27183
Don't have an landline also done my the my sky app and that was useless too just saying I have internet but at 7mbs
@Jde27183 Sky mobile is also the same, 150 dial to talk about the broadband!
Avatar for Jde27183
Don't have sky mobile all I have is there internet and starting to regret it to be honest
@Jde27183 Looking like the social media method is your choice now, sky does not allow the publishing of the contact customer service number, this post number 4 below and expand it all to you get the call us option up.
 https://helpforum.sky.com/t5/Broadband/Moving-Home/m-p/5080372
