Discussion topic: WiFi not working
This message was authored by: LeahTuffin
WiFi not working
  • 2 out of 4 lights are orange on my wifi box
  • app states all connected but wifi on devices not working
Re: WiFi not working
@LeahTuffin   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@LeahTuffin
This link explains the lights on the various hubs
This message was authored by: Ihatemarmite
Mines same, for last hour almost. Says all running fine and clearly not. Are your lights red green red green like mine?  Nothings working to get it back up and ut says no issues. What area are you?
@Ihatemarmite wrote:
says no issues.
@Ihatemarmite
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
