Discussion topic: WiFi speed
This message was authored by: MatLew
Message posted on 07 Sep 2026 09:41 PM
WiFi speed
WiFi is constantly going between 80mbps and 870mbps. I have tried restarting the router etc., but nothing seems to fix it. If I leave it for a few days, it seems to sort itself out.
Find out more
Message posted on 08 Sep 2026 07:30 AM
Re: WiFi speed
@MatLew WiFi speeds are primarily determined by the layout of your home and what it is buikt out of. While you can get some variation in speed on a device which hasn't been moved going from 800Mb/s to 80Mb/s is pretty unusual. It could be caused by inteference but whatever is causing that would have to be pretty close. Another possible explanation could be other people using the connection.
