Discussion topic: WiFi speed
This message was authored by: Prb3
WiFi speed
I've had 150 broadband for more than 14 days when speed was good/ near advertised - for past week it has now dropped by half to 70/80mb/s
Re: WiFi speed
@Prb3 What is showing in your 30 day history in the service checker! Link is below.
Avatar for Prb3
Re: WiFi speed
This does not check WiFi speed which is 70mb/s and has been for a week
Re: WiFi speed
@Prb3 You are wrong it does a daily check! expand your broadband > and you will see each day dated!
Avatar for Prb3
Re: WiFi speed
This is all I get I'm afraid - there are no other areas to expand - I've been checking speed with an online checker(s) which all show 70-80mb/s consistently for last week - before that they were inconsistent but generally 80-130.  So no I'm not wrong!
Re: WiFi speed
@Prb3 You don't see this?
Daily speed for the hub.Daily speed for the hub.
Re: WiFi speed
Avatar for Prb3
Re: WiFi speed
Nope nothing like that
Avatar for Prb3
Re: WiFi speed
Just the screen shot or WiFi and then a link to here
Re: WiFi speed
@Prb3 What hub, white sky max, black broadband hub, black sky Q hub, sky hub, these are the four generations also shown on the link, if you have your own connected what is it!
