Discussion topic: WiFi speed bad
Message posted on 20 Jun 2026 06:13 AM
WiFi speed bad
Message posted on 20 Jun 2026 06:33 AM
Re: BB speed slow
@MichaelCreamer wrote:
New installation. It was fine first day dropped from 300+ mbps to less than 50. Limited equipment, checked via WiFi speed.
That could be wifi rather than broadband then, what does the app say about speed to the hub and of any issues when running the checker?
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following if it's wifi to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 20 Jun 2026 08:02 AM
Re: WiFi speed bad
@MichaelCreamer Your two other threads have been removed as you only need to create one and you need to wait for a reply.
Creating multiple threads is unhelpful and can lead to duplicate replies.
