Discussion topic: WiFi speed. Why does it take so long to open my email. And why does my phone go to 4g in my bedroom
This message was authored by Cumbers This message was authored by: Cumbers
Slow email open speed and 4g only in my bedroom
Re: WiFi speed. Why does it take so long to open my email. And why does my phone go to 4g in my bedr
@Cumbers many phones revert to mobile data when that is faster than a wifi connection. You can change this behavior by going into the phones set up for mobile data and turning off options called something like Wifi assist.
Taken with your other issue it sounds like poor wifi coverage in your home. You can help by making sure your Sky hub is as high innthe room as you can get it and not having the wifi signal blocked by furniture or radiators. However in many homes the free wifi router Sky provides is never going to give gast wifi innevery room which is why therecis a marketvfir third party wifi kit.
