Discussion topic: WiFi signal
Message posted on 04 May 2026 09:15 AM
WiFi signal
Hi we have recently moved to your internet from virgin, but the signal is really weak upstairs often only achieving 1 bar. Which makes gaming etc upstairs unreliable. Is there something that can be done? I don't think we've even had it installed a month yet.
Message posted on 04 May 2026 09:48 AM
Re: WiFi signal
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
