Discussion topic: WiFi signal
This message was authored by: Chrismdunn
Message posted on 04 May 2026 09:08 AM
WiFi signal
Sky was installed last week. WiFi signal is very poor and sometimes gets completely disconnected in one bedroom and in the kitchen.
Find out more
Message posted on 04 May 2026 09:48 AM
Re: WiFi signal
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
