Discussion topic: WiFi signal
This message was authored by: Nf7
Message posted on 23 Dec 2025 01:42 PM
WiFi signal
My WiFi isn't reaching every room
Find out more
Message posted on 23 Dec 2025 01:46 PM
Re: WiFi signal
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
