1
This discussion topic has been answered Discussion topic: WiFi signal weak
This message was authored by: Mikep1984
WiFi signal weak
Good afternoon
 am trying to work at home today with my new sky broadband for the first time and the WiFi strength and signal is terrible. I was promised when taking out this package the WiFi would be strong, I'm probably about 6m from my router. Also my ring cameras are also reporting weak signal issues.
Re: WiFi signal weak
@Mikep1984
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
@Mikep1984
