Discussion topic: WiFi keeps going off
Message posted on 09 Jun 2025 08:40 PM
The WiFi keeps going off and I keep having to reset the router
Message posted on 09 Jun 2025 09:01 PM
Re: WiFi keeps going off
Message posted on 09 Jun 2025 09:07 PM
That's exactly what is happening for me
Message posted on 09 Jun 2025 09:12 PM
I'm having the same problem; been happening on and off the last 2 weeks. I'm in West Cumbria: same area?
Message posted on 09 Jun 2025 09:15 PM
Message posted on 10 Jun 2025 07:36 AM
@AnnoyedPumpkin @Natw5 @Koyli1 running the service checker in the My Sky app overca mobile connection will tell you if Sky are aware of an issue affecting your line. If that doesn't show anything che k the lights on your Sky hub when your connection is down they help,disgnose the issue https://www.sky.com/help/articles/hub-lights-explained-start
Beyond that you will need to call Sky so the issue can be investigated.
Message posted on 10 Jun 2025 08:15 AM
Message posted on 10 Jun 2025 08:18 AM
@Wednesday as advised check the lights on the Sky hub if they are showing the hub is connected but nondata is flowing power down the hub for at least 60 minutes which should clear the fault which is at Sky's end
Message posted on 10 Jun 2025 08:19 AM
Hi @Chrisee, I've of course tried all of the app options to test and self diagnose and manage. Ive tried calling and keep being cut off.
Guys, last night I was fuming so decided to unplug the lot. I unplugged my white hub and I turned off the little box on the wall too. Left it off for at least 45 minutes.
When I turned it back on, it took a little while to load, but everything came back. Checked the settings on the router and I'd moved from channel 11 to channel 1 and when scanning the wifi, it appears there were less signals attached to the channel. I cant promise its fixed it, we've got to test it for longer, but give it a go. If it helps, even a small time, I'm glad
Message posted on 10 Jun 2025 08:57 AM
@AnnoyedPumpkin Logical approach to what is going on will be required, the continual off/on to clear and depending if your are on a copper fttc circuit would be a bad thing to do. If it is interference from others you may be able to spot, you could also try a temp switch off on a band, just depends on what you have using those bands! Is your area jammed with loads of wireless wi-fi about, and also what hub are you using from sky.
Would be good to know if the hub light/lights are changing state when the hub is appearing to not be playing, and if it is a straight, wirless is up but no Internet connection is shown on the device?
Message posted on 10 Jun 2025 09:12 AM
@AnnoyedPumpkin glad you had tried the apps as experience shows that can never be assumed.
For information powering down the hub for an hour should reset the server connection at Sky's end. With around 6 million server connections occasionally one stops passing data - symptoms as I posted above are the lights on the hub shows as connected and the service checker reports the same but no data flows. These servers are physically located in various Openreach exchanges around the country so while Sky's network team do fix thecfault it can take a few days to happen.
