Discussion topic: WiFi signal keeps dropping
This message was authored by: Louises82
Smart plugs and ring doorbell keeps going off due to weak signal. We had someone come the other week from BT and ask if our Internet was running okay as there had been problems in the area. Everything was fine before then. Since the man came the signal keeps dropping and things are disconnecting from the WiFi, like someone else is using it as well as us.
This message was authored by: Mr+Flibbles+86
Re: WiFi signal keeps dropping
