Discussion topic: WiFi signal is poor
Message posted on 31 May 2025 07:01 PM
WiFi signal is poor
Run a test to see what my speed is, lucky to get 90 paying for 150 hub is in an open room
Message posted on 31 May 2025 07:19 PM - last edited: 31 May 2025 07:20 PM
Re: WiFi signal is poor
@Hayley148 What are you testing with for speed, everything else off on the wireless side also?
https://www.sky.com/help/articles/broadband-speeds-explained
And for speed related issues good read.
Message posted on 31 May 2025 07:51 PM
Thanks. I get all that info etc but if your paying for a particular speed and continuously not getting it?
I use downloader on my Firestick and fast.com was recommended to me. My Firestick is in the same room as the hub, constantly glitching and as I say speed shows 90mbp if I'm lucky. Yesterday I was in kbp very annoying
Message posted on 31 May 2025 08:06 PM
@Hayley148 Is the firestick near the hub, you want it to work correct then get the Ethernet adapter and wire it to the hub, you will get no more speed issues with it....
