Discussion topic: WiFi shutting down every few minutes
Message posted on 13 Nov 2025 10:28 AM
Over the last week wifi has gone down intermittently; today more than 20 times since 06.30.
During a live online class it went down 8 times.
In had to stop the session.
all my work is online and it's now urgent that I need help. I cannot afford to cancel any more classes.
The system checks show nothings wrong but there definitely is...
this is an expensive service that has had several price increases this level of outage is really not acceptable.
Please advise.
Thank you
Message posted on 13 Nov 2025 11:28 AM - last edited: 13 Nov 2025 11:31 AM
Re: WiFi shutting down every few minutes
@Jessica441
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Apart from the annual price increase, usually in April in the UK, the price only goes up when discounts end or you're charged for non inclusive landline calls.
