Discussion topic: Issue connection
Message posted on 13 Nov 2025 10:33 AM
Issue connection
Can you check if my connection is good
Message posted on 13 Nov 2025 11:38 AM
Re: Issue connection
@Na2141 wrote:Can you check if my connection is good
@Na2141 you can check yourself with the following..
To begin with try checking if there are any outages in your area using following link.
If this shows no issues you could try running the line test at the following link.
Sky Q 1TB UHD
LG TV
Sky Mobile
