Discussion topic: WiFi setup
This message was authored by: Bre7
WiFi setup
Hi there, we have recently put is sky WiFi and there seems to be a problem with the connection, emails won't loads and it drops in and out all throughout the day and night.
I wondered if we could get someone out to have a look at it to make sure it's running properly
thanks
Re: WiFi setup
@Bre7 Sky do not normally send out engineers but their customer services can talk you through issues but forum members can help.
First thing to check is the setting of Sky's parental protection filter which can affect things like emails. Log into the My Sky app and gonto Product Options the Shield settings should show by default Sky set these to age 13 which maybe too restrictive for you.
wifi ptoblems in your home are very common firstvthing is toncheck you havecthe Sky hub in the best place it can be. Ideally it should becas cdntral in your homecas it can be on a table or shelf above radiators and other obstructions. Morecsuggestions here Sky Help - Slow wifi
Hopefully that will help if you want more help,please just post a question but it helps if you attach yourSky hub's stats to the post see Find your Sky Broadband router statistics
