Discussion topic: WiFi set up not working
This message was authored by: George188
I have just moved into a new flat and started with sky. I have bought the correct micro fitter for my WiFi and it is still not working. I have tested it on the app and it says everything is fine but when I attempt to connect it has a pop up asking us to reset it up and test it. When I follow the pop up it still doesn't work. Can you help I am confused
Re: WiFi set up not working
Have you received notification from Sky that their broadband service to the address has been activated?
For any property with FTTP, a microfilter is no longer applicable.
