Discussion topic: WiFi reach
This message was authored by: cjkerr
WiFi reach
There are some rooms in my house have no wifi rech (including the one next door to the router. Is there a stronger roter. I hve tried range extenders but still having problems.
Re: WiFi reach
@cjkerr all routers are regulated  on the amount of tramsmission power so the answer is no. Check your Sky hub is in the best position out in the open on a surface above obstructions like radiators. If you live in a house or flat with solid internal walls you will struggle
