Discussion topic: WiFi range
Message posted on 02 Aug 2026 05:56 PM
WiFi range
Message posted on 02 Aug 2026 06:01 PM
Re: WiFi range
@TGR1978 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
