Discussion topic: WiFi range
This message was authored by: MattC00per
Message posted on 29 Jun 2025 07:59 PM
WiFi range
Hi, does anyone know if I would be able to get WiFi in my summerhouse which is around 20 meters away from the router. Thanks
Find out more
Message posted on 29 Jun 2025 08:18 PM - last edited: 29 Jun 2025 08:38 PM
Re: WiFi range
Unlikely, particularly through two outside walls (and garden rooms are typically insulated with foil laminate foam which does a particularly good job at attenuating WiFi)
