Discussion topic: WiFi problem
Message posted on 05 Nov 2024 01:30 AM
WiFi problem
Message posted on 05 Nov 2024 08:04 AM
Re: WiFi problem
@tattooqueen15 Sky ldo not guarantee WiFi coversge in every room unless you buy their WiFi Max add-on see https://www.sky.com/help/articles/sky-wifi-max.
However gaming over WiFi is never going to give the best experience due to higher latency and potential packet loss caused by interference. Ideally you would use an etgernet cable to the hub but where that is not praxtical powerline networking adaptters which use mains cabelling to carry the data are a reasonable second best. You can buy kits of two adapters with cables etc from around £40 but plan to get around 20% of the rated speed in praxtice.
