Discussion topic: WiFi poor
Message posted on 12 Mar 2025 08:31 PM
WiFi poor
I got Sky TV and broadband last week and the WiFi does not work properly as it keeps freezing.
Message posted on 13 Mar 2025 07:48 AM
Re: WiFi poor
@PaulaJH it is most likely the issues are caused by the WiFi signal in your home.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
