Discussion topic: WiFi poor connection
Message posted on 12 Jun 2026 10:24 AM
WiFi does not extend upstairs and is only showing 2 bars, poor connection experience, working from home so not ideal
Message posted on 12 Jun 2026 10:27 AM
Re: WiFi poor connection
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
