Discussion topic: Equipment not working
This message was authored by: Steve746
Message posted on 12 Jun 2026 09:27 AM
Booster will not connect to wifi, even though touching hub, plus wifi on phones very slow timing out when try ing to use, though works perfectly on data
Find out more
Message posted on 12 Jun 2026 10:23 AM
Re: Equipment not working
@Steve746 check that the booster is the right type for your Sky hub. If it is a podcsupplied as part of WiFi Max check it is listed in the My Sky app in My Devices. More here https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
