Discussion topic: WiFi password
This message was authored by: Jw771
Message posted on 01 Jun 2026 03:25 PM
WiFi password
How do I change my WiFi password?
Find out more
Message posted on 01 Jun 2026 04:37 PM
Re: WiFi password
@Jw771 see https://www.sky.com/help/articles/find-and-change-your-wireless-password
Find out more
Message posted on 01 Jun 2026 04:38 PM
Re: WiFi password
You need to login to the hub and change it, if you have the Max hub then you can do this via the MySky app so this link will help you to do this:
As soon as you make the change you will have to setup your devices again.
