Discussion topic: WiFi password not accepted
Message posted on 13 Oct 2025 04:40 PM
I've received my new equipment but when I try to connect my devices it's saying the password is wrong. I'm using the password on the hub with the correct upper and lower case and it still won't connect
Message posted on 13 Oct 2025 06:17 PM
Re: WiFi password not accepted
@GordonMurphy Make sure one is not a number / letter capitol O and zero etc 1 i L one small letter i or L can be hard to tell apart!
Message posted on 13 Oct 2025 08:33 PM
With a mobile, scan the QR code printed on the card that comes with the router, that will send the correct code to your phone to connect, once you have done this you can copy and paste it from your security settings on your phone.
It also might be worth just checking that the card has the same information on it as the label on the base of the router in case there has been a mix up!
Failing that do a full reset on the router, for the SR213-O2-W example, press and hold the WPS button until the router restarts, it will then go to factory settings. As printed on the base of the router.
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
