Discussion topic: WiFi outside
This message was authored by: Beckydave123
WiFi outside
Hi everyone,
we are turning our outside sheds into offices, what do we need to do to get the WiFi to reach them?
Re: WiFi outside
@Beckydave123
You would either need to use something like a homeplug or run an Ethernet cable.
Re: WiFi outside
I would not recommend homeplugs/powerline for something like this as distance can be an issue & if your wiring it up correctly it will likely be on a different circuit consumer unit which powerline can struggle with.
I am NOT a Sky Employee
Re: WiFi outside
@Beckydave123
Sky won't provide hardware or support: the wording of the assorted 'guarantees' specifically excludes external buildings.
Ethernet cable, where possible, is always preferable.
