Discussion topic: WiFi only 6.8 mbps!
Message posted on 28 Sep 2026 07:01 PM
WiFi only 6.8 mbps!
Broadband is fine, But WiFi is only 6.8 Mbps. I am on the 900Mbps deal. Anyone got Techical Service number who I can discuss with
Robert
Message posted on 29 Sep 2026 06:53 AM
Re: WiFi only 6.8 mbps!
@Robert260 not at allmuncommon problem. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
