Discussion topic: WiFi on TV won't work
Message posted on 11 Mar 2024 09:46 PM
Message posted on 12 Mar 2024 07:48 AM
Re: WiFi on TV won't work
@Abz12341 if other devices are working normally it sounds like your TV is simply not getting sufficent signal from your hub. You can check thst if while it is connected you go into the Netflix app go to Get Help and run the network test.
You may need some form of booster but often you can improve wifi signal simply by moving the hub out into the open onto a shelf or table.
Message posted on 13 Mar 2024 07:48 AM
Everything is in the same place as it has been for the past 2 years. We can't use anything except sky itself for the TV some of the time. Last night it worked fine again. Night before awful and we had to keep turning things off and on to get it to work. If I connect the TV to my phone hot-spot it works absolutely fine on all apps. So must be Soemthing to do with the sky box I'm thinking?
Message posted on 13 Mar 2024 08:02 AM
@Abz12341Although you say nothing has changed with respect to your home, you do have to consider other area's. If someone close has wifi, it may be possible that you are having interference on the wifi bands, reseting the router can sometimes help but is not always guaranteed. You would be quicker to analyse the surrounding wifi to see if this is an issue. Sometimes items in the home can go bad and aslo cause issues, so do keep it in mind. If you wish to post your router stats we can also take a look.
See top on pinned post on how to do.
