Discussion topic: WiFi off no tv!
This message was authored by: Char62
WiFi off no tv!
I am so fed up of paying £115 per month and having no WiFi or working sky glass!
Re: WiFi off no tv!
@Char62
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you still have broadband problems after 7am use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
▪️I AM NOT A SKY EMPLOYEE ▪️
