Discussion topic: WiFi not working
This message was authored by: Kimmason
WiFi not working
WiFi keep going off
Re: WiFi not working
@Kimmason
It’s worth pointing out that Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
