Discussion topic: WiFi not working
Message posted on 26 Jul 2026 11:24 AM
WiFi not working
My WiFi keeps cutting out it's very much getting on my nerves now it's been a few days since it started and sky still want there full £73 bill for a service that don't work properly sort your WiFi out or I'll be looking elsewhere
Message posted on 26 Jul 2026 11:27 AM
Re: WiFi not working
@Tasha7787
You aren’t actually contacting Sky by posting here as this is a customer ▶️ customer discussion forum where we try to assist other customers.
(£73pm for Broadband and Sky Talk seems high)
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
