Discussion topic: WiFi not working
Message posted on 10 Jun 2026 11:45 AM
WiFi not working
WiFi not working even though checked via sky app and says ok
Message posted on 10 Jun 2026 12:16 PM
Re: WiFi not working
@paul+reynolds
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
