Discussion topic: WiFi disconnected
This message was authored by: Vicki20101
WiFi disconnected
My wifi has gone off
Re: WiFi disconnected
@Vicki20101
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
