Discussion topic: WiFi not working
Message posted on 09 May 2026 07:43 PM
WiFi not working
Internet not working and won't connect to internet
Message posted on 09 May 2026 08:06 PM
Re: WiFi not working
@Olivia1994
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
