Discussion topic: WiFi not working
Message posted on 19 Apr 2026 05:55 PM
WiFi not working
Red light on LOS and no one can connect to internet
Message posted on 19 Apr 2026 07:33 PM
Re: WiFi not working
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
