Discussion topic: No wifi
Message posted on 19 Apr 2026 07:12 PM
No wifi
I don't have any WiFi connectivity - eg the apps on my tv, my mobile phone and iPad are not picking it up. I think there is a problem with my hub
Message posted on 19 Apr 2026 07:28 PM
Re: No wifi
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
