Discussion topic: WiFi not working
This message was authored by: LouMelling
WiFi not working
Hi all of our Internet connection has gone off. Nothing was unplugged or moved and was working fine until about 10 minutes ago. I have tried to test the connection online, it says there is not fault but there must be.
Re: WiFi not working
@LouMelling
