Discussion topic: WiFi not working
Message posted on 09 Jan 2026 03:35 AM
WiFi not working
Flashing green
Message posted on 09 Jan 2026 05:14 AM - last edited: 09 Jan 2026 05:15 AM
Re: WiFi not working
@Laurenkirsty wrote:
Flashing green
A two word post isn't a lot of information to go on… At that time of night it could be essential maintenance taking place.
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
