Discussion topic: WiFi not working
This message was authored by: Markj67
WiFi not working
Power light green Internet light off WiFi light green Voice light orange
Re: WiFi not working
@Markj67
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
