Discussion topic: WiFi Issues
This message was authored by: Sarah933
WiFi Issues
The WiFi keeps dropping so the TV goes off as we have Sky Glass - this happens daily!!
Re: WiFi Issues
@Sarah933
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
