Discussion topic: WiFi not working
Message posted on 14 Nov 2025 12:14 PM
WiFi not working
WiFi not working app says fine
Message posted on 14 Nov 2025 12:34 PM
Re: WiFi not working
@Maisiealice9
The current heavy rainfall may be causing broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
